AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Loose connectors attached to light bulb socket
The large white connector that attaches to the light bulb socket is loose. The light bulb only stays lit when I hold the connector. Can I replace the connectors (White and Orange)? What are the part numbers? If not, how do I tighten them? Model #: KGYS750GQ1.
Try squeezing the loose connector so that it fits tightly on the terminal. Unplug the machine first.
I tried squeezing the connector by hand and with tweezers. I don't want to break it. It still loosens up. Can new connectors be purchased?
You gotta use pliers. Yes, replacement connectors are available anywhere you can buy electrec/electronic service parts. You may even find small kits of assorted connectors at Walmart.
Dryer Repair
