christian1959
#1 Posted : Wednesday, April 7, 2010 10:04:47 AM(UTC)
christian1959
The large white connector that attaches to the light bulb socket is loose. The light bulb only stays lit when I hold the connector. Can I replace the connectors (White and Orange)? What are the part numbers? If not, how do I tighten them? Model #: KGYS750GQ1.
magician59
#2 Posted : Wednesday, April 7, 2010 10:10:46 AM(UTC)
magician59
Try squeezing the loose connector so that it fits tightly on the terminal. Unplug the machine first.
christian1959
#3 Posted : Wednesday, April 7, 2010 12:09:35 PM(UTC)
christian1959
I tried squeezing the connector by hand and with tweezers. I don't want to break it. It still loosens up. Can new connectors be purchased?
magician59
#4 Posted : Wednesday, April 7, 2010 1:08:01 PM(UTC)
magician59
You gotta use pliers. Yes, replacement connectors are available anywhere you can buy electrec/electronic service parts. You may even find small kits of assorted connectors at Walmart.
