elpaul
#1 Posted : Wednesday, April 7, 2010 8:34:08 AM(UTC)
elpaul
I removed all the plastic pieces on the bottom and the impeller to get to a small piece that was making a griding noise when it was running.
I put everything back the way I find it (or so I thought) and now no water is coming out. When I run the dishwasher, the impeller is spinning and the heating element works, but not water.
Help, what did I do wrong?
Also do you know the actual drill bit size to loosen the 1/4 screw on the impeller? Igot it off the first time, but now I cannot remove it.
Thanks,
Eric
elpaul
#2 Posted : Wednesday, April 7, 2010 9:15:52 AM(UTC)
elpaul
Could this be a Float Switch problem?
#3 Posted : Wednesday, April 7, 2010 6:25:21 PM(UTC)
Yes, it could. You have to check if the float is not stuck in the upper position.
What is the complete model number of the dishwasher?
elpaul
#4 Posted : Thursday, April 8, 2010 7:52:47 AM(UTC)
elpaul
It was the Float. I got it fixed. The wife is happy now.
#5 Posted : Friday, April 9, 2010 10:23:09 AM(UTC)
You are welcome. I'm glad it was that simple and you were able to make your wife happy!:) Happy wife is most important thing in men's life!
