I removed all the plastic pieces on the bottom and the impeller to get to a small piece that was making a griding noise when it was running. I put everything back the way I find it (or so I thought) and now no water is coming out. When I run the dishwasher, the impeller is spinning and the heating element works, but not water. Help, what did I do wrong? Also do you know the actual drill bit size to loosen the 1/4 screw on the impeller? Igot it off the first time, but now I cannot remove it. Thanks, Eric
Could this be a Float Switch problem?
Originally Posted by: elpaul  Could this be a Float Switch problem? Yes, it could. You have to check if the float is not stuck in the upper position. What is the complete model number of the dishwasher? Gene.
It was the Float. I got it fixed. The wife is happy now. Thanks
You are welcome. I'm glad it was that simple and you were able to make your wife happy!:) Happy wife is most important thing in men's life!
