realistic
#1 Posted : Wednesday, March 31, 2010 10:06:02 AM(UTC)
realistic
Hello,
My stackable washer/dryer only spins slow. It do not kick into final fast spin. I have replaced timer,motor&pump. I belive the trans is good beacause it dose spin and only the motor is 2 speed. This only leaves the clutch I think. If that is the case, what is the symptoms of a bad clutch? Or what could my promblem be?
thanks so much !!
Joe / APP Team
#2 Posted : Wednesday, May 25, 2011 6:16:43 AM(UTC)
Joe / APP Team
Originally Posted by: realistic Go to Quoted Post
Hello,
thanks so much !!
Realistic,
You're getting there, a slipping clutch or a dragging brake pad, could cause a slow spin,
Part number: AP2046416
Part number: AP2046398
as well as a bent, weak drive coupling, but that usually makes some sort of noise eventually.
The drive system on your washer is very similar to a different manufacturer's so this should help you out,
http://forum.appliancepartspros...-washer-brake-shoes.html
Good Luck,
