Hello, My stackable washer/dryer only spins slow. It do not kick into final fast spin. I have replaced timer,motor&pump. I belive the trans is good beacause it dose spin and only the motor is 2 speed. This only leaves the clutch I think. If that is the case, what is the symptoms of a bad clutch? Or what could my promblem be?
thanks so much !!
Originally Posted by: realistic  Hello, My stackable washer/dryer only spins slow. It do not kick into final fast spin. I have replaced timer,motor&pump. I belive the trans is good beacause it dose spin and only the motor is 2 speed. This only leaves the clutch I think. If that is the case, what is the symptoms of a bad clutch? Or what could my promblem be?
thanks so much !! Realistic, You're getting there, a slipping clutch or a dragging brake pad, could cause a slow spin, Part number: AP2046416
