jim4032
#1 Posted : Monday, August 27, 2007 2:16:36 PM(UTC)
jim4032
maytag neptune, water will not stop entering the machine. If you unplug it , it will stop. pressure switch never opens to advance the cycle. If you blow into it continuity is lost, but when air dome hose is hooked back up it never opens in either wash or rinse.The air dome hose enters the tub underneath and how do you remove it from the machine? If anyone can help me I {and wife} would appreciate it very much.
badace
#2 Posted : Saturday, December 1, 2007 1:56:15 PM(UTC)
badace
I have the same issue with the same model. It seems to be the fill valve but I am not certain. It is very hard to access the unit with out removing everything. Any ideas for me too I would greatly appreciate it.
#3 Posted : Sunday, December 2, 2007 1:34:23 PM(UTC)
You can find complete instructions on how to diagnose and fix your Maytag Neptune washer in the service manual.
water will not shut off (Washer Repair)
by tashaw76 9/21/2012 10:37:06 AM(UTC)
Maytag Neptune washer hot water will not shut off (Washer Repair)
by djensen 6/13/2011 9:51:55 AM(UTC)
Water will not shut off on my wash machine (Washer Repair)
by fetgirlygirl 8/16/2009 2:16:06 PM(UTC)
water will not shut off to ice maker (Refrigerator & Freezer Repair)
by budven 5/15/2009 6:53:23 AM(UTC)
Hot water will not shut off (Washer Repair)
by Keith Lezatte 3/18/2009 1:08:36 PM(UTC)
Water will not shut off (Washer Repair)
by Pastor Jeff 8/14/2008 12:57:12 AM(UTC)
by nvinyard 6/9/2008 8:46:32 AM(UTC)
