nvinyard
#1 Posted : Monday, June 9, 2008 8:46:32 AM(UTC)
nvinyard
Last night out washer overflowed. We discovered that the water is not shutting off. THe spin cycle works and drains. What can cause this problem and how easy is it to fix?
Thanks!
JWLOAR2004
#2 Posted : Tuesday, June 10, 2008 12:04:42 PM(UTC)
JWLOAR2004
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
nvinyard
#3 Posted : Tuesday, June 10, 2008 12:21:16 PM(UTC)
nvinyard
My husband raised the top of our washer and discovered a hose had come off. He replaced the hose and the problem is solved. It is had not been for this forum I would have never had an idea as to what the problem could have been.
abadfish66
#4 Posted : Tuesday, June 10, 2008 12:29:48 PM(UTC)
abadfish66
The hose nvinyard is refering to is the pressure switch hose, a clear rubber hose that goes from the pressure switch to the tub. If this hose is cut, clogged or disconnected from either spot the water will never shut off.
water will not shut off (Washer Repair)
by tashaw76 9/21/2012 10:37:06 AM(UTC)
Maytag Neptune washer hot water will not shut off (Washer Repair)
by djensen 6/13/2011 9:51:55 AM(UTC)
Water will not shut off on my wash machine (Washer Repair)
by fetgirlygirl 8/16/2009 2:16:06 PM(UTC)
water will not shut off to ice maker (Refrigerator & Freezer Repair)
by budven 5/15/2009 6:53:23 AM(UTC)
Hot water will not shut off (Washer Repair)
by Keith Lezatte 3/18/2009 1:08:36 PM(UTC)
Water will not shut off (Washer Repair)
by Pastor Jeff 8/14/2008 12:57:12 AM(UTC)
by jim4032 8/27/2007 2:16:36 PM(UTC)
