MIKEE DREAD
#1 Posted : Tuesday, March 30, 2010 3:20:59 AM(UTC)
MIKEE DREAD
:( The power comes on , compressor starts yets there is no temperture change? please help!
magician59
#2 Posted : Tuesday, March 30, 2010 7:11:36 AM(UTC)
magician59
Couldn't find a reference according to your posted model number. Look in the freezer compartment. You'll need to remove a panel inside. It will eithr be at the back, or on the bottom, of the compartment. Removing it will expose the evaporator. In normal operation, the coils are evenly coated with a thin frost. Partial covering, or thick covering of snowy frost, indicate a problem. Report what you find. (The fan also should be running when the compressor is running).
MIKEE DREAD
#3 Posted : Tuesday, March 30, 2010 8:47:50 AM(UTC)
MIKEE DREAD
The coils have no frost on them but i don't know if the fan is running i think the noise i hear is the compressor,high temperture indicator is on......Hotpoint Future Freezer model...RZA34G...Ind Code 76350120000 s/n704030001......i hope this helps
magician59
#4 Posted : Tuesday, March 30, 2010 9:44:32 AM(UTC)
magician59
It will be very obvious whether the evaporator fan is runnung or not. It's the fan in the freezer compartment at the evaporator. If there is no frost pattern on the evaporator coil at all, either your compressor isn't running, or your refrigerator is undercharged (as in a refrigerant leak), or you just caught it in a defrost mode.
MIKEE DREAD
#5 Posted : Wednesday, March 31, 2010 3:06:40 AM(UTC)
MIKEE DREAD
Yeah fan is working and compressor also can hear liquid running or traveling about/high temperture light on front is on yet still not freezing.....shot in the dark could it possible the thermostat is faulty...Mike
MIKEE DREAD
#6 Posted : Wednesday, March 31, 2010 3:07:56 AM(UTC)
MIKEE DREAD
there is no leaking from what can see thanks
magician59
#7 Posted : Wednesday, March 31, 2010 7:07:48 AM(UTC)
magician59
Most refrigerant leaks are minute, and very gradual. You won't see it; especially if it's inside the insulation. That's why they make refrigerant leak detectors. It sounds, froom your description, like you either have a very serious restriction in your system, or a low refrigerant charge.
MIKEE DREAD
#8 Posted : Wednesday, March 31, 2010 7:17:24 AM(UTC)
MIKEE DREAD
Would that suggest that the high temperture light on......
