:( The power comes on , compressor starts yets there is no temperture change? please help!
Couldn't find a reference according to your posted model number. Look in the freezer compartment. You'll need to remove a panel inside. It will eithr be at the back, or on the bottom, of the compartment. Removing it will expose the evaporator. In normal operation, the coils are evenly coated with a thin frost. Partial covering, or thick covering of snowy frost, indicate a problem. Report what you find. (The fan also should be running when the compressor is running).
The coils have no frost on them but i don't know if the fan is running i think the noise i hear is the compressor,high temperture indicator is on......Hotpoint Future Freezer model...RZA34G...Ind Code 76350120000 s/n704030001......i hope this helps
It will be very obvious whether the evaporator fan is runnung or not. It's the fan in the freezer compartment at the evaporator. If there is no frost pattern on the evaporator coil at all, either your compressor isn't running, or your refrigerator is undercharged (as in a refrigerant leak), or you just caught it in a defrost mode.
Yeah fan is working and compressor also can hear liquid running or traveling about/high temperture light on front is on yet still not freezing.....shot in the dark could it possible the thermostat is faulty...Mike
there is no leaking from what can see thanks
Most refrigerant leaks are minute, and very gradual. You won't see it; especially if it's inside the insulation. That's why they make refrigerant leak detectors. It sounds, froom your description, like you either have a very serious restriction in your system, or a low refrigerant charge.
Would that suggest that the high temperture light on......
