rtexass13
#1 Posted : Wednesday, June 4, 2008 7:11:00 AM(UTC)
rtexass13
the refrigerator stays to cold. it wont shut off. changed temp control and still the same problem. could you give me some idea's what might be wrong. thanks rick
#2 Posted : Thursday, June 5, 2008 1:40:31 AM(UTC)
Most probably low on refrigerant, pull back freezer panel and check frost pattern
If partially frosted, that's your problem.
GE fridge water dispenser slows to trickle, speeds up when filter is twisted (Refrigerator & Freezer Repair)
by Guest 1/11/2024 5:03:35 AM(UTC)
Basic things need on Cricket (Trash Compactor Repair)
by Johnalex 7/6/2022 11:07:18 PM(UTC)
Water barely trickles from dispesmser with filter installed (Refrigerator & Freezer Repair)
by BLEBOW 6/5/2022 11:17:17 AM(UTC)
need help getting trick to open cooktop for service (Oven Repair (including Ranges and Cooktops))
by av8ndoc 9/21/2015 10:59:30 PM(UTC)
Tricky dishwasher kick plate (Dishwasher Repair)
by AppliancesRcool 1/19/2015 1:37:07 PM(UTC)
Water trickles and tiny ice cubes (Refrigerator & Freezer Repair)
by louisd 3/7/2014 6:05:33 PM(UTC)
Water trickles when off (Washer Repair)
by Porkins 3/14/2013 7:59:40 AM(UTC)
tricky (for me ) problem! (Washer Repair)
by gpl2112 12/14/2012 10:04:12 AM(UTC)
rick (Dryer Repair)
by rjboy 10/30/2012 5:50:32 AM(UTC)
Wierd Refrigerator Trick (Refrigerator & Freezer Repair)
by ALConfederate 8/21/2012 5:24:00 PM(UTC)
Washer during spin cycle sound like brick in drum and spins slower and unevenly (Washer Repair)
by w_hurt 4/11/2012 6:26:54 AM(UTC)
rickfry1 (Washer Repair)
by rickfry1 1/28/2012 6:24:05 AM(UTC)
GE washer shock replacement any tricks? (Washer Repair)
by Jayword 12/22/2011 11:27:49 AM(UTC)
Cold water only trickles; normal setting problems (Washer Repair)
by bench 9/29/2011 4:22:11 PM(UTC)
Cold water trickling (Washer Repair)
by mommahuck 6/21/2011 5:44:20 PM(UTC)
