heat element on with timer off cycles off/on element shows no gnd with wires un hooked
Check to make sure that there is not a burnt wire in the control panel(on the timer).
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Start dryer run 2 minutes, cycle complete sign come on, check vent it’s clear
