Yester day i blow out the lint and today its not getting any heat any ideal what it can be?
Originally Posted by: mloy333  Yester day i blow out the lint and today its not getting any heat any ideal what it can be? Take off the lower panel in the front. Then in the back on the bottom left of the dryer is the heater hoiusing. It is held in place by a 5/16 screw on each side of it. Remove the scrtews, and pull down on the housing, and out, and look at the coil, and see if it is bad. Also there is a thermostat on the housing to check. If you had an ohm meter it would be great. make sure the dryer is unplugged when you do this. Tom ApplianceEducator.com - Parts
