mloy333
#1 Posted : Thursday, March 25, 2010 11:56:14 AM(UTC)
mloy333
Yester day i blow out the lint and today its not getting any heat any ideal what it can be?
kayakcrzy
#2 Posted : Friday, March 26, 2010 4:41:12 AM(UTC)
kayakcrzy
Take off the lower panel in the front. Then in the back on the bottom left of the dryer is the heater hoiusing. It is held in place by a 5/16 screw on each side of it. Remove the scrtews, and pull down on the housing, and out, and look at the coil, and see if it is bad. Also there is a thermostat on the housing to check. If you had an ohm meter it would be great. make sure the dryer is unplugged when you do this. Tom ApplianceEducator.com - Parts
frigidaire oven wont heat after self clean (Oven Repair (including Ranges and Cooktops))
by chalooch101 10/14/2019 5:04:21 AM(UTC)
AMANDA #AMC5143AAS WONT HEAT (Microwave Repair)
by kimidoll2642 6/11/2019 9:34:52 AM(UTC)
Maytag performa wont heat up (Dryer Repair)
by gr8filed 4/22/2018 8:41:56 AM(UTC)
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
Frigidaire Stovetop elements, oven, and broiler wont heat (Oven Repair (including Ranges and Cooktops))
by janniiie 1/17/2016 2:35:18 PM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Dishwasher wont heat, checked normal things (Dishwasher Repair)
by Whomda 11/7/2015 3:56:04 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
by thildy 5/7/2015 2:26:44 PM(UTC)
by Jim Winkels 4/5/2015 5:08:25 PM(UTC)
