The washer screaches near the end of the spin cycles. Loud- high pitch sound. Like something is rubbing. I have narrowed down the problem to the lower tub and upper transmission areas. Somewhere in-between it appears. Any ideas on what the problem might be? And information on disassembling the part(s). I cannot separate the inner tub from outer tub to lookover / assess. Thanks for any suggestions.
