shadetreehandyman
#1 Posted : Tuesday, March 23, 2010 6:01:37 AM(UTC)
shadetreehandyman
The washer screaches near the end of the spin cycles. Loud- high pitch sound.
Like something is rubbing.
I have narrowed down the problem to the lower tub and upper transmission areas.
Somewhere in-between it appears.
Any ideas on what the problem might be?
And information on disassembling the part(s). I cannot separate the inner tub from outer tub to lookover / assess.
Thanks for any suggestions.
shadetreehandyman
#2 Posted : Tuesday, March 23, 2010 7:22:06 AM(UTC)
shadetreehandyman
test reply only
