Hello.My microwave keeps shutting down for some reason.Thefirst time I try to use it it will run for maybe 30 seconds and then shuts down.It says to reset the clock and I do.After that when I try to use it it runs for about two seconds and then shuts down.Any good ideas?Thanks
Sounds like you need a new control board.
Originally Posted by: magician59 Sounds like you need a new control board. Are you talking about the smart board or the whole control panel sub assembly
Originally Posted by: magician59 Just the board. Is that a tough thing to change out?Do you know of any online instruction that may help?Thanks
