I have a LER4634EQ1 that just stopped working the other day. I replaced a bad thermal fuse and it worked fine for 1 day. Now it won't turn on again. It heats up but won't spin. The new thermal fuse is still good. What else could it be?
Can you hear the motor running?
No the motor doesn't turn. I tore it all the way down to the motor and it won't spin when I turn it on. Bad Motor????
The motor is wired in series with the door switch, the thermal fuse, and the timer. I would test the less expensive parts before settling on the motor.
Ok so im still at a loss, the thermal fuse, door switch, and motor are all good. Heat comes on when I turn the timer on and the timer moves through the cycle but the motor still won't spin. Is it the timer? How do I test it? What else could it be?
