easye88
#1 Posted : Monday, March 22, 2010 11:48:10 AM(UTC)
easye88
I have a LER4634EQ1 that just stopped working the other day. I replaced a bad thermal fuse and it worked fine for 1 day. Now it won't turn on again. It heats up but won't spin. The new thermal fuse is still good. What else could it be?
magician59
#2 Posted : Monday, March 22, 2010 1:04:33 PM(UTC)
magician59
Can you hear the motor running?
easye88
#3 Posted : Monday, March 22, 2010 8:35:34 PM(UTC)
easye88
No the motor doesn't turn. I tore it all the way down to the motor and it won't spin when I turn it on. Bad Motor????
magician59
#4 Posted : Tuesday, March 23, 2010 9:21:26 AM(UTC)
magician59
The motor is wired in series with the door switch, the thermal fuse, and the timer. I would test the less expensive parts before settling on the motor.
easye88
#5 Posted : Thursday, April 1, 2010 2:38:06 PM(UTC)
easye88
Ok so im still at a loss, the thermal fuse, door switch, and motor are all good. Heat comes on when I turn the timer on and the timer moves through the cycle but the motor still won't spin. Is it the timer? How do I test it? What else could it be?
Guest (4)
