about 12 years old. the refrigerator got warm within a day or so. the compressor seems to be running in other words it is warm to the touch and is humming. I think I am turning the defrost timer and finally it turns off the refrigerator and then I can click it back on. this is with the thermostat to the coldest temp. the temp of the freezer is about 9to 10 degrees. I have thermostat set on 7.
:eek: :eek: Originally Posted by: dnelsen ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) about 12 years old. the refrigerator got warm within a day or so. the compressor seems to be running in other words it is warm to the touch and is humming. I think I am turning the defrost timer and finally it turns off the refrigerator and then I can click it back on. this is with the thermostat to the coldest temp. the temp of the freezer is about 9to 10 degrees. I have thermostat set on 7.
