Here ia a parts breakdown
Replacement parts for FRG FRS26LF7DS7 | AppliancePartsPros.comHere is a tech sheet, includes how to force a defrost
ftp://ftp.electrolux-na.com/Pr...F/Anderson/240389616.pdfDoes sound like a defrost problem
Remove the evaporator coil covers in the freezer so you can see the coils.
If they are heavily ice up then you have a defrost problem.
Force a defrost, see the tech shhet.
Does the heater heat up, don't burn your fingers.
If it does you probably need a new defrost control board. Item 23 in the "Controls" section, listed as F23 at the bottom.
If it does not heat up, it is easiest to check the thermostat and the heater with a meter for continuity.
Sometimes you can see where the heater has burned out or the thermostat is bulged.
If you do not have a meter,I would suggest you purchase one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
