jordad
#1 Posted : Monday, March 23, 2009 9:44:45 AM(UTC)
jordad
Good DaY, to whomever is helping me!
My refrigerator will not cool. I thought maybe it was ice build up, so I unloaded all foods, freexe and refrig. Turned off the unit, unplugged it and let it sit for about 14 hours. There was some water in the drain pan below when I looked. After cleaning the inside I plugged the unit back in and turned both refrig. and freezer back on. I thought all was good, as the freezer worke, as it has been and even the refrigerator chilled to the 40 degrees. I was happy! But, 4 days later, same problem. The refrigerator side would not cool. What might it be? If this has something to do with a defrost mechanism, or the behind the scene parts, can I make the repair or do I have to call a repair person. I'm not scared to do it myself, if I understand all I need to do. But, if it's better to call I will. I just want some idea of what the problem may be so I don't get ripped off, especially labor. If you could approximate, how long should the job take to make the reapir? Thank you! Dee
#2 Posted : Monday, March 23, 2009 10:18:50 AM(UTC)
Here ia a parts breakdown
Replacement parts for FRG FRS26LF7DS7 | AppliancePartsPros.com
Here is a tech sheet, includes how to force a defrost
ftp://ftp.electrolux-na.com/Pr...F/Anderson/240389616.pdf
Does sound like a defrost problem
Remove the evaporator coil covers in the freezer so you can see the coils.
If they are heavily ice up then you have a defrost problem.
Force a defrost, see the tech shhet.
Does the heater heat up, don't burn your fingers.
If it does you probably need a new defrost control board. Item 23 in the "Controls" section, listed as F23 at the bottom.
If it does not heat up, it is easiest to check the thermostat and the heater with a meter for continuity.
Sometimes you can see where the heater has burned out or the thermostat is bulged.
If you do not have a meter,I would suggest you purchase one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Warm Refrigerator - #HSS25GFTA WW (Refrigerator & Freezer Repair)
by Edwv30 5/5/2024 12:17:37 PM(UTC)
GE warm refrigerator, new inverter. (Refrigerator & Freezer Repair)
by Guest 11/24/2023 4:51:12 AM(UTC)
Freezer warm refrigerator cold (Refrigerator & Freezer Repair)
by oldfartsexpress 5/27/2018 8:34:46 AM(UTC)
Warm Refrigerator (Refrigerator & Freezer Repair)
by Just_me 7/17/2016 8:09:30 PM(UTC)
Warm Refrigerator, Cold Freezer (Refrigerator & Freezer Repair)
by phillb 2/27/2013 5:24:40 AM(UTC)
by mfjohnston 6/8/2012 2:31:45 AM(UTC)
Jenn-Air warm refrigerator section, freezer fine (Refrigerator & Freezer Repair)
by j34castro 7/26/2011 12:51:39 PM(UTC)
warm refrigerator (Refrigerator & Freezer Repair)
by gvernon 5/30/2011 6:02:58 AM(UTC)
Warm refrigerator freezer OK (Refrigerator & Freezer Repair)
by jzielinski49@comcast.net 4/17/2011 8:54:53 AM(UTC)
warm refrigerator but freezer is fine (Refrigerator & Freezer Repair)
by bmt274 10/22/2010 10:38:10 AM(UTC)
Cold freezer, warm refrigerator (Refrigerator & Freezer Repair)
by dgandt 7/26/2010 11:16:32 AM(UTC)
Failing icemaker and warm refrigerator (Refrigerator & Freezer Repair)
by cshulamit 6/11/2010 7:52:44 PM(UTC)
by Nicholson 5/7/2010 10:08:33 AM(UTC)
by dnelsen 3/22/2010 6:23:19 AM(UTC)
warm refrigerator, frost on inside back panel (Refrigerator & Freezer Repair)
by mbnash 3/23/2009 9:44:19 PM(UTC)
