AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
water still in bottom after washes clicking noise where drain hose attaches
stopped using the unit a few weeks ago . took apart the screws at the bottom put fingers in pulled out hair & gunk, still washes but stays full just below door open level with dirty water . read up on similar problems could be the Piston & nut assembly for check valve?? is there any other thing i could check? gsd5200g00w i wrote it down gsd5208g00ww but i think i was wrong . i will look in the drain hose see i i can tell its plugged (thought these units self garberate the water before exiting?).
Hi Paul, There are the parts which you have to check: The piston & nut assembly, the drain hose for a clog and/or twist or bend, the air gap (on top of the sink) for a clog, the check valve for a clog, the drain pump motor, the drain pump flapper and the drain pump for a clog. To check most of these parts the dishwasher has to be removed from the cabinet. Here are the break down diagrams for the GE dishwasher Model GSD5200G00WWGene.
Dishwasher Repair
