Davyd
#1 Posted : Tuesday, May 27, 2008 5:06:55 PM(UTC)
Davyd
Hello My dryer has been squealing for about two weeks, and now it's making a metal to metal noise like worn brake pads making contact with rotors, willing to tackle the problem not sure if it's a bearing, belt or pulley,and does anyone if these parts are avail in a kit.
Thanks in advance
:D
#2 Posted : Thursday, May 29, 2008 11:04:25 AM(UTC)
Hi Davyd,
Remove the front panel and check the glides (#34 on the door break down diagram).
Remove the drum and check the rear bearing (#13 on the cabinet break down diagram).
Here are the break down diagrams for the White Westinghouse dryer Model DE500ADW5 (model similar to yours).
ShamanNY
#3 Posted : Wednesday, July 9, 2008 5:56:06 PM(UTC)
ShamanNY
Davyd
Just wondering if you got the problem fixed and if its not too late
I had a similar problem on a comparable model
it was the idler pulley that came apart (look at Fig 1 item 18)
while you are at it change the belt.
Noisy Dryer (Dryer Repair)
by family guy 8/24/2013 3:12:08 PM(UTC)
Loud noisy dryer through whole cycle but works (Dryer Repair)
by joannesnauta 3/8/2012 10:04:17 AM(UTC)
noisy dryer when running sqeaky and vibrates (Dryer Repair)
by Dale Powers 5/11/2011 12:41:42 PM(UTC)
Noisy dryer (Dryer Repair)
by pncope29@gmail.com 10/11/2010 4:49:25 PM(UTC)
by juneschild 8/17/2010 10:34:51 AM(UTC)
noisy dryer (Dryer Repair)
by lramsey00 1/20/2009 3:43:19 PM(UTC)
by ge1209 11/13/2008 1:42:22 AM(UTC)
by marti73 10/28/2008 9:27:57 AM(UTC)
by tmta4irish 7/24/2008 4:17:52 PM(UTC)
by james steward 3/17/2008 9:16:56 AM(UTC)
by dan523 3/4/2008 9:42:10 AM(UTC)
Noisy Dryer - Sounds like we are polishing rocks when it is running (Dryer Repair)
by this old house 1/26/2008 5:43:40 AM(UTC)
noisy dryer when on (Dryer Repair)
by ellashoe 10/21/2007 8:58:02 PM(UTC)
