Hello My dryer has been squealing for about two weeks, and now it's making a metal to metal noise like worn brake pads making contact with rotors, willing to tackle the problem not sure if it's a bearing, belt or pulley,and does anyone if these parts are avail in a kit. Thanks in advance :D
Davyd
Just wondering if you got the problem fixed and if its not too late
I had a similar problem on a comparable model it was the idler pulley that came apart (look at Fig 1 item 18) while you are at it change the belt.
