AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer won't spin at full speed, replaced thrust assy
I work on commercial and Industrial laundry equipment. My friend owns this washer and when it tries to spin it slips, the agitator rotates and it finally spins at a reduced speed. I have already replaced the thrust assy and it is better, but still not right. The owner overloads with work clothes, could this be something as simple as a belt? or could there be a problem in the brake package assy? HELP!
Originally Posted by: ApplianceJunk  Thanks, I'll Check those. Still, is it possible it could be a belt problem?
You Don't happen to know Jim Hunter do you?
Washer Repair
