WasherGuy
#1 Posted : Tuesday, May 27, 2008 6:23:38 AM(UTC)
WasherGuy
I work on commercial and Industrial laundry equipment. My friend owns this washer and when it tries to spin it slips, the agitator rotates and it finally spins at a reduced speed. I have already replaced the thrust assy and it is better, but still not right. The owner overloads with work clothes, could this be something as simple as a belt? or could there be a problem in the brake package assy? HELP!
ApplianceJunk
#2 Posted : Tuesday, May 27, 2008 9:40:29 AM(UTC)
ApplianceJunk
Check this out and see if it helps.
Maytag Docs
ApplianceJunk
#3 Posted : Tuesday, May 27, 2008 9:49:01 AM(UTC)
ApplianceJunk
WasherGuy
#4 Posted : Tuesday, May 27, 2008 12:14:01 PM(UTC)
WasherGuy
Originally Posted by: ApplianceJunk Go to Quoted Post
Thanks, I'll Check those. Still, is it possible it could be a belt problem?
WasherGuy
#5 Posted : Tuesday, May 27, 2008 12:23:52 PM(UTC)
WasherGuy
You Don't happen to know Jim Hunter do you?
