I have replaced the rear bearing, belt, top felt, and the heater coil. The dryer ran great. I moved and put the unit in storage for 6 months. We took it out and set it up and now it will not heat. Any suggestions on what part(s) I should replace? Thanks for your help.
Check the heating element for a starting place, those guys have been known to separate when bounced around.
