Dryer won't start when press to start switch is activated....replaced press to start switch still doesn't work....timer is clicking but stops when door opened and restarts clicking when door closed.....what to check next?
You drop the front bottom panel on this guy. Their are 2 fuses. One mounts on the heater housing. Another is hidden behind the filter housing. The filter housing has to be removed to get to it. It is fairly easy but looks difficult. Clean out the lint and make sure the vent pipe is clear of obsticals. The fuse looks like this: Stove Top.jpg (393kb) downloaded 10 time(s).SublimeMasterJW attached the following image(s):
