Hello, I am a newbie to this board but I have a problem with my GE Profile cook top. One of the right burners does not work and when I try to use it I get an error code F 112. I have tried the reset procedures but the problem persists. GE was unable to tell me what the error code means and I have not been able to find any info through web searches.
Thanks for your help.
I too have JUST had my cooktop do the same thing. It started beeping on its own like an alarm and when we checked it this F112 started flashing. The cooktop is "hard wired" so we shutoff the breaker and when it came back on the F112 was gone, and the burners heated, but now one of the "hot surface" indicator lights is on even though we are not using it. I am going to call GE now, but they better have a better response then, "I don't know" This thing cost me $2,000 and it is ONLY 4 yrs old.
Originally Posted by: pammy52  I too have JUST had my cooktop do the same thing. It started beeping on its own like an alarm and when we checked it this F112 started flashing. The cooktop is "hard wired" so we shutoff the breaker and when it came back on the F112 was gone, and the burners heated, but now one of the "hot surface" indicator lights is on even though we are not using it. I am going to call GE now, but they better have a better response then, "I don't know" This thing cost me $2,000 and it is ONLY 4 yrs old. We had GE out and they had to replace one of the burners. The F112 never stopped even after the hard reset. The build quality is poor for a appliance costing this much.
Hi NSAN Could you please post the detailed procedure to replace RDT as you described or where I can find the repair steps? I am having the same problem on my monogram cooktop now. Thank you very much for your help! extreme98 Originally Posted by: NSAN  My GE cooktop has similar problems.Flashing F113.I found service manual inside of them.Accoding to this that your F112 is Left AFT side heater was over temp.I did replaced Heater Assy.Then fix it.Cause of this problem is RDT temp sensor was bad I think.I have twice this problems!This RDT was made by Cyntec Taiwan company.I've been tell to GE.But no response.Cyntec also.:mad: NSAN
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Rank: Guest
