dam1954
#1 Posted : Monday, March 8, 2010 10:44:52 AM(UTC)
dam1954
The damper door does not open to allow cold air into the main compartment. How would I go about isolating what to replace?
magician59
#2 Posted : Monday, March 8, 2010 11:21:27 AM(UTC)
magician59
Here's the part number: Part number: AP3772850
dam1954
#3 Posted : Monday, March 8, 2010 12:24:47 PM(UTC)
dam1954
Can I test the damper door motor to confirm that it is the problem?
magician59
#4 Posted : Monday, March 8, 2010 12:30:59 PM(UTC)
magician59
You can; but I don't have a schematic to tell me what kind of voltage it normally operates on. You don't want to let the smoke out of it.
dam1954
#5 Posted : Monday, March 8, 2010 2:06:11 PM(UTC)
dam1954
the damper is 115 volt. I checked the 2 wires on the side of the motor. One appears to connect to the sensor so I am assuming the other should be power. when I check accross the wires I do not see any voltage. Does the voltage come from the temperature control? or is the ground wire used as the common for the voltage? Should I have voltage coming from the temperature switch?
#6 Posted : Tuesday, March 9, 2010 1:15:30 AM(UTC)
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389610.pdf
It should answer your questions.
