portland fridge
#1 Posted : 18 years ago
portland fridge
My reservoir hose on the bottom is spirting water when you pour. Can anyone verify that the only fix is to cut the hose and put on a coupling? I just had sears out, and I don't trust this diagnosis, not to mention sears has a markup on the proposed part of 140% markup (I think - the part is available online for $67 - sears wants $167). The trouble if I do this fix is still there. The problem is where the hose meets the reservior. So if I cut the hose, put on a coupling, wont it still leak from the reservior??
Has anyone else had this problem, and know how to actually fix it?
The proposed part that I looked up online for pricing while the "repairman" was here is: 5303918258 which is an electrolux part for what looks like a washer?
Thanks!
avgjoe
#2 Posted : 18 years ago
avgjoe
I have a frigidaire with the exact same problem! I looked the part up and the # was ps469559 listed as water tank reservoir replacement kit for around $70. I'm planning on fixing it myself by this weekend and I'll let you know what I figure out!
portland fridge
#3 Posted : 18 years ago
portland fridge
Hey avgjoe, did you fix your hose on the reservoir tank? If so, how did it go? Something you would suggest I do? Thanks in advance!
