Our GE washer will not go to the spin cycle. All other functions are okay. Need help on selecting a new part. thanks.
Look inside the lower service panel and see if you can find some tech notes that will allow you to troubleshoot the machine.
The likely culprit is your speed control board, but sometimes the door lock assembly is also the problem when it does not confirm that the door is locked, so check it also.
