tcpr12
#1 Posted : 15 years ago
tcpr12
Our GE washer will not go to the spin cycle. All other functions are okay. Need help on selecting a new part. thanks.
sidfink43
#2 Posted : 15 years ago
sidfink43
Look inside the lower service panel and see if you can find some tech notes that will allow you to troubleshoot the machine.
The likely culprit is your speed control board, but sometimes the door lock assembly is also the problem when it does not confirm that the door is locked, so check it also.
GE washer will not spin (Washer Repair)
by MS104 9 years ago
GE washer will not spin with heavy load (Washer Repair)
by carpe 11 years ago
by Rico Whiskey Delta 12 years ago
GE washer will not spin or agitate (Washer Repair)
by tarzandude43 12 years ago
Ge washer will not spin or agitate (Washer Repair)
by Paul Di 14 years ago
GE Washer will not spin (Washer Repair)
by mazdaboss 15 years ago
GE Washer will not spin on heavy loads (Washer Repair)
by hmorton 15 years ago
by bfreeman91080 15 years ago
GE Washer will not spin or agitate (Washer Repair)
by casshley 15 years ago
by tcahapw 16 years ago
GE washer will not spin nor agitate (Washer Repair)
by Evans 16 years ago
ge washer will not spin or agitate (Dishwasher Repair)
by m-fuson 16 years ago
GE Washer will not spin on rinse cycle (Washer Repair)
by mguy77 17 years ago
by csol147462 17 years ago
