shlomo
#1 Posted : Wednesday, March 3, 2010 4:36:10 PM(UTC)
shlomo
After my Kenmore dishwasher stopped after cycling - I discovered the wiring harness burnt at the quick disconnect tab as well as the circuit board on the control board. Should I replace both? Did another fault cause the burn/current draw? Does a new fuse come with the control board? ShouLd I buy all 3 and put it back together?
Any help is appreciated
Rob
magician59
#2 Posted : Thursday, March 4, 2010 8:17:49 AM(UTC)
magician59
You'll want to check the electrical connection under the machine. A loose ground or neutral can cause this.
#3 Posted : Friday, March 5, 2010 3:44:28 AM(UTC)
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535451.pdf
[COLOR="Blue"]Should I replace both?[/COLOR]
Depends how bad the harness is but it is usually a good idea.
Any poor connection at the harness plug will cause it to overheat again.
[COLOR="Blue"]
Did another fault cause the burn/current draw?[/COLOR]
Probably you will have to check each component for resistance.
Perhaps by inspecting which wires/connections heated up on the harness connector you can narrow down what caused it.
There is always a possibility that it was the harness to control board connection itself that was the problem.
[COLOR="Blue"]Does a new fuse come with the control board?[/COLOR]
I do not think so.
[COLOR="Blue"]
ShouLd I buy all 3 and put it back together?[/COLOR]
Unless you can determine the cause I would not.
All 3 parts are going to run you around $170.00 dollars.
Unless the unit is in excellent shape, it does not make sense to invest this into an old unit.
Plus you may need other parts.
