jacka28
#1 Posted : Sunday, May 18, 2008 2:21:13 PM(UTC)
jacka28
When the water goes to fill up tray inside the ice maker, it is leaking all over the inside of the freezer. What should I be looking for to fix it?
kooler
#2 Posted : Monday, May 19, 2008 1:08:48 PM(UTC)
kooler
This one's not an easy call, you'll have to observe the water fill when it's calling for it to fill (after ice harvest)... Is it over-filling the cube reservoir? Is it running down the rear wall of the freezer? You may have to remove a rear wall panel to view the tube the water travels thru to the ice maker while it's in the fill cycle which is just a few seconds... Good luck!
