When the water goes to fill up tray inside the ice maker, it is leaking all over the inside of the freezer. What should I be looking for to fix it?
This one's not an easy call, you'll have to observe the water fill when it's calling for it to fill (after ice harvest)... Is it over-filling the cube reservoir? Is it running down the rear wall of the freezer? You may have to remove a rear wall panel to view the tube the water travels thru to the ice maker while it's in the fill cycle which is just a few seconds... Good luck!
