kitchenaiddw
#1 Posted : Monday, March 1, 2010 8:30:28 PM(UTC)
kitchenaiddw
Please help...I broke a glass in the dishwasher, and some of the broken glass pieces fell through the small openings in the draining unit on the bottom of the dishwasher ( I'm not sure, but it might be called the coarse filter?). How do I remove the lower spray arm and whatever else needs to be removed to get the unit open so I can clean it out? I tried to twist the small knob on top of the spray arm, but it seems very solidly attached, I'm afraid to break it off.
meachamcb
#2 Posted : Monday, March 8, 2010 12:09:47 PM(UTC)
meachamcb
The knob may be a lefthand thread. CBM
abtrman
#3 Posted : Wednesday, March 10, 2010 9:07:53 AM(UTC)
abtrman
I had the same problem a few years back.The unit was under warranty so I called a tech.He said the glass fragments would be ground-up by the dishwasher.Sure enough,after two full cycles the glass was gone.If you cannot wait,the spray arm,water supply to the spray arm and that flying saucer shaped disc at the bottom must be removed to get at the large items trapped.I found tooth picks and small misc. debris.It's not that difficult a job for someone with some mechanical ability.Good luck.
Guest (4)
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
Kitchenaid dishwasher pump? (Dishwasher Repair)
by Guest 6/11/2023 10:15:41 AM(UTC)
KUDS02FRSS2 Kitchenaid dishwasher (Dishwasher Repair)
by RepairDude61 7/2/2022 3:45:51 PM(UTC)
KitchenAid Dishwasher Not drying (Dishwasher Repair)
by louie@DFW 4/8/2022 5:15:51 PM(UTC)
Kitchenaid Dishwasher Multiple Errors (Dishwasher Repair)
by flamingvan@yahoo.com 12/6/2021 3:49:43 AM(UTC)
Kitchenaid Dishwasher F9E4 (Dishwasher Repair)
by louisd 10/17/2021 4:22:16 PM(UTC)
Kitchenaid Dishwasher diverter motor replacement (Dishwasher Repair)
by kitchdish 5/28/2021 12:32:35 PM(UTC)
KitchenAid Dishwasher Issue (Dishwasher Repair)
by facecard 3/19/2021 6:20:02 AM(UTC)
KitchenAid Dishwasher KUDS30IXBL Thermal Fuse (Dishwasher Repair)
by Ed Explains It 3/16/2021 10:34:44 AM(UTC)
KitchenAid Dishwasher will not complete cleaning Cycle (Dishwasher Repair)
by KyKatt 12/16/2020 12:23:50 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
KitchenAid dishwasher filling up when turned off (Dishwasher Repair)
by RinOakland 9/14/2020 8:50:00 AM(UTC)
KitchenAid Dishwasher pops open(latch changed) (Dishwasher Repair)
by saads 8/8/2020 9:51:27 PM(UTC)
Kitchenaid Dishwasher Not Starting (Dishwasher Repair)
by willmt10 6/28/2020 4:22:06 PM(UTC)
(Help) KitchenAid Dishwasher wont fully drain on normal cycle (Dishwasher Repair)
by ToNeG24 5/28/2020 9:16:06 PM(UTC)
