jehosaphat
#1 Posted : Saturday, February 27, 2010 8:00:36 AM(UTC)
jehosaphat
Does not fill up with enough water. Replaced with new water valve but did not
solve problem. Water shuts off before rising up enough to move float as before. When I manually move the float lever underneath it does shut the water off. Both the float lever and the float inside the tub move very smoothly with no resistance. The water just never fills up to the proper level to work correctly.
magician59
#2 Posted : Saturday, February 27, 2010 8:30:56 AM(UTC)
magician59
jehosaphat
#3 Posted : Saturday, February 27, 2010 9:42:09 AM(UTC)
jehosaphat
Thank you very much for your quick reply.I did do the auto function test. It did not fill to the correct level or note that anything was wrong. Was I supposed to do anything other than push the sequence of buttons. I tried normal cycle afterwards and it did the same thing again of inadequate water level. I am missing something here and do not know what. Thanks for your help.
magician59
#4 Posted : Saturday, February 27, 2010 2:55:22 PM(UTC)
magician59
It sounds like you need to replace the control board. Part number: AP403806
. Given the age of the machine, though, You may do better to replace the machine.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
