grandma
#1 Posted : Thursday, May 15, 2008 8:59:02 AM(UTC)
grandma
:confused:My Estate dryer stopped drying clothes! It's heating, the heating coil gets red & the drum tumbles, but the clothes aren't drying as they should. I put an average size load in & after 4 hours, they still weren't completely dry. Please advise me as to what may be the problem.
SublimeMasterJW
#2 Posted : Thursday, May 15, 2008 9:47:52 AM(UTC)
SublimeMasterJW
Most of these drying problems are due to some sort of venting issue. Most likely the dryer needs to be blown out and the vent pipe cleared.
SublimeMasterJW
#3 Posted : Thursday, May 15, 2008 10:03:59 AM(UTC)
SublimeMasterJW
A picture tells a thousand words Doorhandle.pdf (152kb) downloaded 24 time(s).
SublimeMasterJW attached the following image(s):
grandma
#4 Posted : Monday, May 19, 2008 1:36:11 PM(UTC)
grandma
Thank you so much for your suggestions; it was the correct answer. We checked the venting & actually there was a "kink" in the vent tubing. The dryer is now drying clothes & the venting areas are now cleaned out! ( I hope this is the right place to reply to your suggestions.) This repair forum is a great thing!
grandma
#5 Posted : Monday, May 19, 2008 1:40:21 PM(UTC)
grandma
:)Thank you so much for your suggestions; it was the correct answer. We checked the venting & actually there was a "kink" in the vent tubing. The dryer is now drying clothes & the venting areas are now cleaned out! ( I hope this is the right place to reply to your suggestions.) This repair forum is a great thing!
My dryer stopped drying clothes! (Dryer Repair)
by grandma 5/15/2008 8:55:30 AM(UTC)
