tdjtorkelson
#1 Posted : Friday, February 26, 2010 9:30:56 AM(UTC)
tdjtorkelson
Hi, Over the last few months our electric range will at random times beep and the "Bake" indicator on the display panel will start to flash. Pressing the "Cancel" button will clear this. Last weekend we did a self-clean for about two hours and ever since then we can't get the oven to bake. We can press the "Bake" or "Convect" button and set the temperature, but the temperature display will start increasing immediately and within 30 seconds the oven will beep and show that it has reached the temperature we set, but the oven will still be cold? I was able to get the broiler to work but last night it seemed that the broiler element would only stay on for a few minutes but the display showed everything to be working? After using the broiler for about 10 minutes the display would only work when we pushed the "Clock" and "Clean" buttons. I have a feeling the control panel needs to be replaced but could the lower element or temperature sensor also need replacing? The bottom element is fully covered by the bottom panel of the oven and the oven is much cleaner since we used the self-cleaning so I think the bottom element should be fine. Any suggestions on how to check the sensor or element to see if they need replacing? Thank you for your help. Tom
#2 Posted : Friday, February 26, 2010 8:15:03 PM(UTC)
Most likely the problem is a bad control board. I do not think that anything else has to be replaced at this time.
- The control board Part number: AP4422522
