Mooresville78
#1 Posted : Thursday, February 25, 2010 12:22:09 PM(UTC)
Mooresville78
I put 2 sweaters in on time dry for 20 minutes the dryer shut off with 2 minutes left and the sensing light was on I can take a wet cloth and wipe the 2 sensing strips and i can get the read out to go to wet but dryer will still not turn on ?
magician59
#2 Posted : Thursday, February 25, 2010 12:30:47 PM(UTC)
magician59
On a timed dry cycle, the moisture sensor does not affect the timer.
Mooresville78
#3 Posted : Thursday, February 25, 2010 1:19:24 PM(UTC)
Mooresville78
Does samething on any setting
magician59
#4 Posted : Thursday, February 25, 2010 1:43:02 PM(UTC)
magician59
sounds like a timer problem. That isn't Mooresville, Indiana, is it?
Mooresville78
#5 Posted : Thursday, February 25, 2010 5:32:15 PM(UTC)
Mooresville78
Mooresville, Indiana. is correct.
Mooresville78
#6 Posted : Thursday, February 25, 2010 7:53:28 PM(UTC)
Mooresville78
No matter what setting I have the dryer on when i press start it makes a clicking noise then goes to sensing and i cannot get it to do anything else.
#7 Posted : Friday, February 26, 2010 2:27:37 PM(UTC)
Perform the troubleshooting as described in the Tech sheet for your Cabrio dryer.
Whirlpool dryer sensing light won't go off (Dryer Repair)
by lsgress 1/9/2012 3:55:12 PM(UTC)
