I put 2 sweaters in on time dry for 20 minutes the dryer shut off with 2 minutes left and the sensing light was on I can take a wet cloth and wipe the 2 sensing strips and i can get the read out to go to wet but dryer will still not turn on ?
On a timed dry cycle, the moisture sensor does not affect the timer.
Does samething on any setting
sounds like a timer problem. That isn't Mooresville, Indiana, is it?
Mooresville, Indiana. is correct.
No matter what setting I have the dryer on when i press start it makes a clicking noise then goes to sensing and i cannot get it to do anything else.
Originally Posted by: Mooresville78 No matter what setting I have the dryer on when i press start it makes a clicking noise then goes to sensing and i cannot get it to do anything else. Perform the troubleshooting as described in the Tech sheet for your Cabrio dryer. Gene.
