AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
How to replace actuator handle and spring on GE dishwasher
When I took the door of the dishwasher apart I found one of the pivot arms broken on the actuator handle and the spring was laying loose. I feel the handle will be self explanatory but not sure where or how the spring mounts. Based off of the picture I assume it slides over the right hand pivot arm? Any information on how the handle and spring mount would be appreciated. I purchased a new handle and spring just need to install. Thanks
Did you ever get an answer or figure it out on your own? I have the same problem, a broken arm on the handle actuator. I've ordered the part, but its not obvious how it fits back in the handle with the spring. Any hints?
Dishwasher Repair
