Tim Brewer
#1 Posted : Tuesday, February 23, 2010 7:10:50 PM(UTC)
Tim Brewer
When I took the door of the dishwasher apart I found one of the pivot arms broken on the actuator handle and the spring was laying loose. I feel the handle will be self explanatory but not sure where or how the spring mounts. Based off of the picture I assume it slides over the right hand pivot arm? Any information on how the handle and spring mount would be appreciated. I purchased a new handle and spring just need to install. Thanks
ajbuch
#2 Posted : Wednesday, January 23, 2013 6:10:35 PM(UTC)
ajbuch
Did you ever get an answer or figure it out on your own? I have the same problem, a broken arm on the handle actuator. I've ordered the part, but its not obvious how it fits back in the handle with the spring. Any hints?
Jeff RI
#3 Posted : Wednesday, February 20, 2013 10:06:47 AM(UTC)
Jeff RI
http://forum.appliancepartspros...r-spring.html#post800475
I just made this post in a similar thread and posted some photos to help with the re-installation of the spring.
Flyrodchuck
#4 Posted : Wednesday, May 15, 2013 5:07:13 PM(UTC)
Flyrodchuck
Great help. Thanks
