Cynthia Fletcher
#1 Posted : Tuesday, February 23, 2010 1:13:32 PM(UTC)
Cynthia Fletcher
My dryer will turn on & off. It's not staying heated. The heat sensor is causes it do get red, but it won't stay on. When you open the dryer door it has sweat on it. What do I need to do?
#2 Posted : Tuesday, February 23, 2010 3:35:48 PM(UTC)
Cynthia,
Most likely the problem is obstructed vent line. Make sure it is clean all the way through the vent outlet and the vent hose behind the dryer is not kinked or bent.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL REX5634KQ1 | AppliancePartsPros.com
