Dryer stopped working. Light turns on when door is open. The timer/heat select dial makes clicking noise when it is plugged in. When the start button is pushed it does nothing.
This is the first problem we experienced with the washer.
Originally Posted by: Frago  Dryer stopped working. Light turns on when door is open. The timer/heat select dial makes clicking noise when it is plugged in. When the start button is pushed it does nothing.
This is the first problem we experienced with the washer. Frago, In order to provide most accurate advise we need the complete model number of the washer (or dryer?). Gene.
