Frago
#1 Posted : Tuesday, May 13, 2008 4:42:40 PM(UTC)
Frago
Dryer stopped working. Light turns on when door is open. The timer/heat select dial makes clicking noise when it is plugged in. When the start button is pushed it does nothing.
This is the first problem we experienced with the washer.
#2 Posted : Wednesday, May 14, 2008 1:42:06 PM(UTC)
Frago,
In order to provide most accurate advise we need the complete model number of the washer (or dryer?).
