wreng11468@mac.com
#1 Posted : Tuesday, May 13, 2008 7:02:09 AM(UTC)
wreng11468@mac.com
I have a a ge oven that won't ignite the bake burner. Every other burner works fine. Only the bake doesn't. When I turn it on I can see that the igniter does not glow. Is the problem the igniter or can there be a different problem causing the igniter not to glow?
#2 Posted : Tuesday, May 13, 2008 6:54:41 PM(UTC)
Remove the oven floor and the flame spreader. Check for 120V to the bake igniter while the control calls for Bake.
If there is 120V then replace the bake igniter.
If there is no 120V then replace the control board.
- The part number for the bake igniter is AP2014008
- The part number for the control board is AP2025074
Here are the break down diagrams for the GE range Model JGBP85BEA2BB
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 3/3/2024 10:10:13 AM(UTC)
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
GE Oven Control board locking after starting oven. Model # CGS985SETASS (Oven Repair (including Ranges and Cooktops))
by Mike I 1/15/2024 10:55:45 PM(UTC)
GE oven bake element (Oven Repair (including Ranges and Cooktops))
Belarus 72yrsoldwoman 10/27/2023 6:22:03 PM(UTC)
Frigidaire Gallery Range Oven Won't Get to Temp (Oven Repair (including Ranges and Cooktops))
by Guest 5/5/2023 7:41:56 PM(UTC)
Amana range oven elements stopped working (Oven Repair (including Ranges and Cooktops))
by Primary123 6/8/2022 1:40:04 PM(UTC)
Monogram Range Oven Mod ZGP486LDR4SS (General Talk)
by astringfield 12/29/2021 4:58:36 AM(UTC)
GE gas range oven won’t come on (Oven Repair (including Ranges and Cooktops))
by Guest 6/6/2021 3:02:24 PM(UTC)
Viking range ovens, broiler, and griddle don’t turn on (Oven Repair (including Ranges and Cooktops))
by Guest 5/19/2021 11:02:20 AM(UTC)
Whirlpool range oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by Guest 5/10/2021 12:58:16 PM(UTC)
Phantom GE Oven Model (Oven Repair (including Ranges and Cooktops))
by pervis 4/25/2021 2:16:40 AM(UTC)
GE Oven - touch pad problem (Oven Repair (including Ranges and Cooktops))
by tinamonsaas 12/2/2020 7:23:09 PM(UTC)
Norge Oven Timer preventing the oven from working (Oven Repair (including Ranges and Cooktops))
by Stilltrying2 10/10/2020 1:37:47 PM(UTC)
GE Oven Tuns Off Randomaly (Oven Repair (including Ranges and Cooktops))
by gregciccol 8/9/2020 10:08:42 AM(UTC)
