Replacement parts for WHIRLPOOL GU1200XTLQ0 Undercounter Dishwasher | AppliancePartsPros.comHere is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208533399.pdfAs Qtip said, it could be a door latch switch.
Could be that the thermal fuse has blown (Item 6 in Section 2)
Check that the unit is getting power re: wirenuts etc.are OK.
On the original problem, check the keypad with a meter, see the tech sheet.
Normally the way you trouble shoot this type of problem is to check the keypad and if it is OK then you replace the control board. Still a bit of a crap shoot but your odds are better.
You may want to try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
